Old 17-May-2012, 1:14 AM   #10
signals unlimited
Can't explain exactly....could be that the signal is a refraction or you are picking it up in the antenna side lope. You may need an off dirrection to play this channel. If that is a problem and you need to constantly fuss with the dirrection, it would be a lot easier from the comfort of your living room via rotor than on the roof manually.
