Old 26-Aug-2010, 8:05 PM   #2
mtownsend
Originally Posted by kenais View Post
I'd like to receive the channels from the SW and at least WEUX to the SE.
Hello and welcome!
Are you absolutely set on getting WEUX? There is another Fox affiliate, KMSP (channel 9), that is located in the same place as all the other transmitters in Minneapolis.
If you stick with only the Minneapolis stations, then your antenna setup will be very simple. Just point an antenna like the Winegard HD7694P or Antennacraft HBU-33 toward compass heading 231ยบ and you're done.
If you really want stations from both the Minneapolis and La Crosse-Eau Claire markets, then you will need to use an antenna rotator -OR- install two antennas and combine them. You can get stations from both metros, but there are consequences to consider with either of these solutions.
Unless you have a pressing need for WEUX, I would just go for the Minneapolis stations.
