Old 15-May-2012, 11:18 PM   #9
OberGeiss
Just a report back to the Forum....appreciate all your incisive input.
I ended up mounting the low band VHF on the opposite end of the house using 3" wall brackets. Separation between the Yagi and the V4 not an issue now.
I first cabled the low band V4 directly to a reliable HD set and was surprised to see nearly all UHF and VHF signals coming in fine on the V4.
I then utilized the AD UHF/VHF combiner (joining the yagi and the V4) and fed the output from the combiner to the input of my balanced 3 way splitter (then to 3 sets). Doing this I lost the low band stations I had just captured when the V4 had been cabled directly to one set.
Happened to have a Channel Master DA hanging around so figured I would try that between the V4 ant and the combiner. That worked fine so now getting all my VHF and UHF throughout the home.
Again many thanks.
David
OberGeiss is offline   Reply With Quote
