Tv Antennas and Tv Reception
Examples of very weak.
KPXN-DT 38 ION is very weak , minus -2.9 NM(dB) , with a 2 edge reception path.
KOCE-DT 48 PBS is very weak , minus -4.0 NM (dB) , with a 2 edge reception path.
The 2 edge reception paths will produce more fading of the signals and the very weak signals leave no fade margin .
Install the HD7084P or better yet a HD8200U antenna with the Kitztec amplifier. . Here is a 2 antenna combination that is 4 feet shorter then HD8200U. .
Winegard HD5030P and HD9095P. Combine them with a UVSJ .
