Old 14-May-2012, 10:39 AM   #3
signals unlimited
Use the Winegard HD7080P. It is Low and High VHF/UHF and will work well on all channels on your report, including the pending stations. Starting with one antenna pointed to your North stations is a good starting point. You may want to leave two or three feet of mast below your mount to accomidate a second antenna later. No pre-amplifier is needed at the antenna. If you are only using two sets use a two set splitter. If you go into the distribution splitter to feed all outlets, use a distribution amplifier just ahead of the splitter rated 3 db times the amount of outlets. Terminate all unused outlets. If you go to the second antenna, DO NOT COMBIND into one coax. Before scaning for channels, be sure to configure your sets for ANTENNA channels, not cable.
