Old 14-May-2012, 12:38 AM   #1
kvorkian
Antenna and Install Advice (SoCal, CA)
Let me start by saying that I've been traversing the forums for awhile and appreciate seeing the help that the experienced few provide those of us that are new and challenged.
As such, I thought I'd look for advice on my situation to confirm I'm heading in the right direction. My signal map can be found here: http://www.tvfool.com/?option=com_wr...de65a8cb1ce1f2
I'm finding that my location in SoCal, CA is not prime for receiving OTA signals given the surrounding hills - I read that towers in the area are awaiting FCC approval. I'm looking to replace my current satellite installation with an OTA antenna.
Here is my setup. I ran RG6 throughout my two-story house with dual drops to all rooms - sourced from a roof-mounted satellite dish, with runs through the attic, terminating at a splitter in an office closet that runs to all rooms.
I'm planning for a chimney-mounted roof install (Ronard 2224 Y mount) for the antenna leveraging my existing RG6 - plan to leave satellite cables alone and run from TV antenna into the closet. Was considering running dual antenna's: Winegard HD7698P and Winegard HD7082 - given forum advice provided to other's in my surrounding area.
Question. Is this a good approach? Was planning to install one antenna first; and then consider adding the second to pick-up additional stations, as needed. Also, what's the best way to run the signal to multiple rooms (splitter advice) - I plan to run the signal to (2) active TV's, at this time. Will I require an amp to compensate for signal loss or to power the signal to multiple TV's? Can the signal's be combined from the two antenna's or should I run them separate to prevent reception bleed/distortion? (which is possible, as I ran two sets of cable to each room). Also, If there is better advice to go with a single antenna - would certainly prefer it.
Appreciate all the help. Thanks in advance. -Raspy.
kvorkian is offline   Reply With Quote
