Tv Antennas and Tv Reception
The way to find out about reception with ANY Antenna is to try it.
Put the SS3000 in or close to the east facing window.
The SS3000 antenna needs to be plugged in so the built in amplifier will work.
Face the SS3000 antenna out the window to the east.
And set the Tv to scan for channels. Having the Tv scan for channels is important , having a antenna at a location and not receiving a channel and then moving the antenna to a new location , the Tv needs to scan for channels to see what can be received.
The Tv stations to be received are to the north East and south East.
You will notice that the information is begining to repeat , the reason is , it is important.
A good place for SS3000 is in the East facing window facing out the window and scan for channels.
If you choose to try a antenna on the west patio move the antenna away from the building , the building is reducing/blocking reception to the East so getting a antenna clear of the building is important. Do not set the antenna on the ground , higher is better.
From here on out the information will repeat more and more.
