Thread: Help Experts!
Old 12-May-2012, 11:04 PM   #6
Electron
Tv Antennas and Tv Reception
The Tv stations are of moderate signal strength to weak signal strength. The Tv stations to receive are on the East side of the building of the direction of East.
A antenna outside on the west side will likely improve reception some.
However the best reception will happen on the East side of the building. A antenna on the East side of the building should be up as high as possible. Not mounted just above the ground.
Here is the first choice for a antenna on the outside of the East side of the building , Winegard HD7000R antenna with a Winegard AP8700 preamp aimed at about 90 degree magnetic compass , (East).
The second choice on the outside of the East side of the building is a Terk HDTVo antenna aimed East.
The third choice on the outside of the East side of the building is a Antenna Craft HDX1000 aimed East.
The fourth choice is a Terk HDTVa antenna put in the window or close to the window that faces East.
Here is how to aim indoor and outdoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.amazon.com , http://www.winegarddirect.com , http://www.antennacraft.net.
