Tv Antennas and Tv Reception
The Tv transmitters are about 14 miles away or so to the west on Lookout mountain. The reception is LOS = Line Of Sight. You can see the Red lights of the transmitter towers at night , Yes? . I lived in Denver for 12 years. Right now I understand that a , ANT751 or ANT751R antenna with No Amplifier , mounted above the roof and aimed west. And as a test , A Known to be good matching transformer (balun) connected to the antenna and A Known to be good coax is connected to the matching transformer , and the Known to be good coax is run through open window or door direct to a Known to be good Tv that will receive the DIGITAL Broadcast Tv Transmissions will receive , many , many , many , Digital Tv channels. What is the make and model number of the Tv?? Is a converter box being used??
