That's what I gathered too, Electron. Antennaweb.org recommended a deep fringe antenna, with only 38.1 listed. My experience with the indoor antenna demonstrated that was the only reliable station. Growing up with an antenna in a house not far from here, we had 4, 6, 7, 12, and 13 reliably. The address there on TVFool shows reception weaker than here. What was confusing to me with TVFool, was the color code/antenna placement. If I can get all of the green with the leaves on the trees, I'll be happy. I've enjoyed doing the research and thanks for your help. I'll let you know the results after I do the set-up.
