Old 10-May-2012, 7:49 PM   #10
Electron
Tv Antennas and Tv Reception
I found a misstatement and corrected it to say , The Federal Antenna Law Does Not Prohibit the owner of the apartments from saying Yes you can put a Tv antenna on the roof or outside wall. Here is a antenna the can receive Ok. It is a omnidirectional. Omnidirectional is good because receives all directions. And not so good because receives all directions , signal reflections (multipath) off of other buildings and trees and etc. can disrupt reception. Omnidirectional antennas work most of the time but not all of the time. The only way to find out is to mount a omnidirectional directional antenna as much as possible clear of obstructions , like get the omnidirectional antenna above the roof. Thats true of any type and kind of Tv antenna. Tv antennas like elbow room , nothing crowding in to upset reception. Channel Master CM2002 Metrostar omnidirectional antenna. http://www.channelmasterstore.com .
