Old 10-May-2012, 5:22 PM   #6
Electron
Tv Antennas and Tv Reception
Above the balcony. If the the HDX1000 is mounted up high so the antenna has better clearance of the roof , I suspect that all of the Canada stations/channels to the east will be received and also the USA stations/channels to the south south east. Aim the HDX1000 at the USA stations/channels at about 149 degree magnetic compass reading. The perfered way to get the coax from the outside of the building to the inside of the building is to drill a hole through the wall. Here here is a flat coax that will also work , in the http://www.solidsignal.com , search box type in , holland 144823 . Here are places to buy antennas and etc. , http://www.solidsignal.com , http://www.antennacraft.net , http://www.amazon.com , http://www.amazon.ca , http://www.trentondistributors.com , http://www.saveandreplay.com , http://www.canadapost.ca/shopper.
