Thanks to the Fox affiliate, you will need a High-VHF/UHF antenna. Get a Winegard hd7698P. A pre-amp will only be helpful if you're running 50 feet or more of cable to the TV. Otherwise, it will only add noise to the circuit and not do you any good. That antenna might help with FM reception, but is not explicitly designed to do so.
A one-antenna solution that includes FM would be a lot bigger, as it would be designed to catch low-VHF TV. An example would be the Winegard HD8200P. You would be better off to hang up the wire dipole antenna that manufacturers used to include with receivers.
