Old 9-May-2012, 8:43 PM   #1
guitarguy
OTA - Montreal, Quebec (condo)
Looking for some recommendations. I live in a condo, so an outdoor/roof mounted antenna is out of the question for the time being. I may try to convince the other tennants to change up the rules, since any antenna will be in the back of the building, and won't ugly up the front, lol.
Anyways, I live on the top floor (4th), so I hope that will help my case. I have an absolutely clear and un-obstucted view to the main transmitters I'd like to pick up (the US ota stations, NBC, CBS, FOX, etc.).
My report can be seen HERE.
In the above report, it says that I should be able to pick up most of the channels with an attic mounted antenna. I'd rather not start messing with the attic either (I believe that is still 'common area'), but I do have my laundry room in the back of the building where I wouldn't mind installing some kind of antenna.
Basically, I'd be looking for a recommendation on if it would be possible to get a decent number of channels with my antenna indoors, and what would be a good antenna to do the job, or any other advice that may help!
Thanks!
Edit: In the intrest of providing as much info as possible, there is vinyl siding on the outside (no brick where I would need the antenna pointed). Building is wood frame, I don't believe there is any concrete blocks or anything like that.
guitarguy is offline   Reply With Quote
