Old 25-Aug-2010, 6:31 PM   #3
Tigerbangs
TV Reception Maven
Tigerbangs's Avatar
An additional tip here: the Tucson stations should also come in at your house if you aim your antenna slightly south-east of South Mountain. While they are a bit weaker than the very strong Phoenix stations, they still put enough signal over your area to make them available.
mtownsend is absolutely right about mounting an antenna either ON your roof, or on an eave that can site the antenna over the highest part of your roof. Attic mounts in very hot climates can be a real issue because HVAC equipment mounted in an attic and the widespread use of foil-backed insulation in roofs Additionally, since many homes in Phoenix have stucco exteriors, you'll find that stucco and CBS construction really blocks YV reception. An exterior antenna is far and away your best solution .
