You should be able to use a much simplier system. I would recomend an RCA ANT751. This is a UHF/VHF antenna and should receive all of the UHF to your South and Southwest, including the only VHF channel in your report, 8 PBS at 200 degrees. The amplifier should not be needed unless you have a long run of coax and/or you are hooking up multipul sets.
