Old 8-May-2012, 8:22 AM   #16
geot
Originally Posted by Electron View Post
I provided real facts and information that a HD7080P or HD8200P All channel antennas are not required. There is no requirement to receive channels 2 thru 6 with a all channel antenna at your location. And the receivable stations channels are not so weak as to require a very large antenna. I do a lot of research before I recommend a antenna and etc. . The receivable stations channels are moderate signal strength at your location. The ANT751 or ANT751R antenna receives well to the , front , back and angles at the antenna. The gain of the ANT751 is about 5 dB. I have stated my recommendation and what I believe will work with no rotor at your location.
I am also going to do the same at my friends house. Her location is the following
http://www.tvfool.com/?option=com_wr...de657bf1d539b0
Can you look at this and let me know what you think. You have been a great help.
geot is offline   Reply With Quote
