Tv Antennas and Tv Reception
I provided real facts and information that a HD7080P or HD8200P All channel antennas are not required.
There is no requirement to receive channels 2 thru 6 with a all channel antenna at your location.
And the receivable stations channels are not so weak as to require a very large antenna.
I do a lot of research before I recommend a antenna and etc. . The receivable stations channels are moderate signal strength at your location. The ANT751 or ANT751R antenna receives well to the , front , back and angles at the antenna. The gain of the ANT751 is about 5 dB.
I have stated my recommendation and what I believe will work with no rotor at your location.
