Old 7-May-2012, 10:15 PM   #12
signals unlimited
The Digitenna can be purchased at www.cceparts.com.
I can understand if you are not up to mounting an antenna on the roof as suggested, but that or an attic installation of the antenna recommended by Electron would be more reliable and less agravation in the long run.You can hook up to the input of the first splitter in your system to feed all of your sets, or you can simply hook up the indoor antennas to all sets if you are up for that. Each one will need to be adjusted somewhat and the results will vary from room to room...If you go that route, buy one Digitenna and one RCA to see what works where.
If needed will assist you with either hook-up you choose.
