Old 7-May-2012, 8:09 PM   #4
Electron
Tv Antennas and Tv Reception
As to the grounding situation , it is best that you contact and electrican for grounding methods in Canada. . The Tv/s Must scan for the Digital Broadcast Tv Channels sometimes called to 'Antenna Channels' or 'Air Channels' in the Tv setup menu because the transmissions travel through the air from the transmitting antenna to the receiving antenna. DO Not scan for cable Tv channels.
