Old 24-Aug-2010, 7:36 PM   #5
rockstar45
Originally Posted by mtownsend View Post
Actually, NBC and Fox are not broadcasting on VHF channels. They are on channels 46 and and 19, respectively. The get mapped to channels 6.x and 11.x on your TV through the magic of virtual channel numbers (http://en.wikipedia.org/wiki/Virtual_channel), but the signal is really being sent on channels 46 and 19.
WSWP (PBS) and WVNS (CBS) are the only real VHF broadcasts in your area ("real" channels 10 and 8).
It looks like your attic-installed UHF antenna is the one being affected by wet weather. You are probably not having any problems with your VHF antenna.
It's not necessarily the water in the air that is changing your signal readings. It might be caused by water on your roof or on other objects in your signal path (e.g., wet leaves on trees, neighboring buildings, etc.) that are causing the signals to bounce around differently. If the multipath (multiple reflected signals being picked up by your antenna) is getting worse, it can make life difficult for your receiver. Your receiver's signal meter is reporting a "quality" estimate (it's not a "strength" estimate), so the numbers will go down when the multipath gets worse.
If your VHF antenna is on the roof, can you put the UHF antenna up there too? Getting the antenna up on the roof is a great way to reduce multipath and clean up the signal.
Hi Bill.
Thanks for the advice. I'll try rotating it when I get the courage to get on the ladder again. No rotor.
I have a 10 foot mast with about 10 feet of coax between the VHF antenna and the amp. I'll see what I can do to reduce the cable length. The total cable I have in the system is about 90 feet from the antenna to the TV. I may be able to reduce this to about 60 by being creative.
If it doesn’t help with my drop outs at least I’ll have a stronger signal. I’ll be sure to report back.
rockstar45 is offline   Reply With Quote
