Old 7-May-2012, 4:00 PM   #6
jaysrif
Originally Posted by signals unlimited View Post
I assume you are looking for an several indoor antennas to hook up to several TV sets. This may work ok if your home is wood frame with a shingle roof. I recommend that you purchase an RCA ANT1600R and move it to the sets one at a time to be sure that this, or any indoor antenna will fill your needs. Indoor reception may vary from room to room.
This antenna is flat wall mounted, and will work best if you can face it North or South to receive the stations to your North. It is bi-directional. If this antenna fails, let us know and we can design a system that you can mount in your attic and split to connect all of your sets.
Correct we will need antennas for all of our tv's. Our house is wood frame however we have a clay tile roof.
I will look at the RCA ANT 1600R like you recommended.
Thanks!
jaysrif is offline   Reply With Quote
