DTV and antenna in one downlead
I live in 29582 zip code. I have direct tv but I want to add an antenna to get local stations and use the same coax cable. My dtv receiver has an off air input. Can I use a diplexer and combine the signal, and then use one to split the signal at the receiver and then go in to the off air input? I cannot run a second cable because it would require drilling another hole in a masonry wall. Any help is appreciated. Also. I plan on using a MS 2002 winegard mounted in the attic. Here is my location
http://www.tvfool.com/?option=com_wr...9fbe0ea6d89c46
Dennis
Reason: http://www.tvfool.com/?option=com_wrapper&Itemid=29&q=id%3d9fbe0ea6d89c46
