The antenna claims of mileage are no more than guess work by antenna marketing hacs. The ANT751 with a Winegard 8700 pre-amplifier, (instead of the distribution amp) mounted outside with a clear view toward the stations should receive the channels to your South, and the strong stations to the North. If you want a larger antenna, Shop for a Winegard High VHF/UHF antenna.
