Your antenna is directional. It does have a fairly wide beamwidth, but the position that you are aimed to leaves channel 28 at 62 degrees in the weakest spot of the antenna. An RCA ANT751 should work, but you may need to play with directions moving towards channel 28, but not far enough to cause problems with your other received channels. You may not need your amplifier. Try with and without. If that fails or you want to resolve with your current antenna, you can install a rotor from the maker of your antenna an Aspen Eagel Roto 100 (a very good match). This would be easy to install, as it will work with your existing coax, provided you ditch your amplifier or replace with a Winegard 8700 amp, and have no splitters between the antenna and the rotor box.
