Old 5-May-2012, 10:01 PM   #4
signals unlimited
You do have most of your channels to your South. If you have no need to receive stations from the other directions, a rotor would not be needed. However I would recommend that you go to the Winegard 8200 antenna. That is a more powerfull all channel antenna and may do better around the trees. Without the ability to tweek the antenna you may need the extra gain of the larger antenna. If you do need the other directions, I would stay with the 7080P and the rotor, not multipul antennas, coax, A/B switches ect.
