Old 23-Aug-2010, 9:18 PM   #1
jkh
Antenna help please for Southern NH
Hi,
I want to install a TV antenna so I will be able to receive HD channels from the Boston and Manchester NH areas.
This is my TVFool report: http://www.tvfool.com/?option=com_wr...9fbec94cbbc237
There are some trees mostly surrounding the east side of my property. I will run a 50’+ coax cable from antenna to a splitter and then use the existing wiring in my house for 2 TV sets.
I am thinking about mounting the 10’ antenna mast on a corner of my house that faces south. Currently a satellite dish is installed there and sits about 15’ above the ground.
Could someone please help me with the type of antenna/preamp or maybe a rotor I will need to buy, as well as any other mounting kits and/or installation suggestions?
Thank you.
jkh is offline   Reply With Quote
