I have tried removing the amplifier for a short time with no real change in result. How can I test my signal to see if I do need to reduce the strength? Is it possible that I am too close?
Also, when you say point the antenna at 145 degrees you are basically suggesting pointing it in the opposite direction, thinking the signal may in fact be to strong?
