CKAL-DT Channel 49 Calgary update
CityTv (CKAL-DT) have now received CRTC approval and should be ready to go with some testing very soon as their 100Kw ERP transmitter set up and ready to go on Channel 49. It is using the same panel antenna array as Global CICT-DT so if you receive Global well, then you should also receive CityTv equally well or better at double the ERP.
