Old 4-May-2012, 6:48 AM   #4
Have you tried pointing the antenna at about 145°?
Also, the signals are extremely powerful because you are so close to the local transmitter towers. You need to completely remove the amplifier from the system. I'd expect any amplifier to overload which will make reception more difficult. You have so much signal power, you may actually need an attenuator.
