Old 2-May-2012, 6:54 PM   #2
I'm sorry you're having trouble posting a link to your TV Fool report. It sounds as if you have been able to generate a report, if so you should be able to copy the web address from the address bar of your browser, then paste it into your post.
Guidelines When Asking for Help
Because the terrain in the area appears to be relatively level, I don't anticipate a significant change in signal conditions between locations along Colonel Leonard Rd. So here is a link to a report for the general vicinity. http://www.tvfool.com/?option=com_wr...de65e0c55d7c8d
The signal conditions indicate that a mid-sized antenna such as a Winegard HD7694P aimed due west would provide coverage of both Baltimore and DC signals.
How many TVs do you plan to connect?
How long will the coax be if run from the antenna to the most distant TV?
