If you look at your report you will find major networks located in all of the station groups.
There are many advantages to receiving multipul network stations from multipul markets, including a larger varity of sports franchises, news cast, and local programing. For as little as $75.00 a rotor can be added to your all channel system. allowing you to choose your stations. Even a clever two antenna system will not reliabily provide more than two markets. I have a tread called to rotate or not to rotate where I have shared some tuning tips and advantages, along with some reasons not to use a rotor posted by some who strongly dissagree with their use. It's your system you deside. 1/2 an antenna system may be enough for your friend.
