Old 1-May-2012, 11:20 AM   #58
samve33
It had more than once crossed my mind that I had the wrong cable and I had check, but I had thought I had put the HD7698P on that new one. I should had realized it when I mentioned about that connector falling off. The connector on that new cable isn't likely to fall off. I was switching the cables at the grounding block because I hadn't ran the second cable at the time. That's when I got crossed up. I think I'll need to aim the HD7698P just a little more. I've got a few jobs I need to get to first, so it might be a few days before I can get to it. Think I'll add a second set of guy lines too, don't really like the way the mast feels in the middle.
samve33 is offline   Reply With Quote
