Thread: help please
Old 13-Aug-2010, 2:18 PM   #5
Tower Guy
Originally Posted by Dave Loudin View Post
Any other thoughts from the collective?
I agree that an HD-769X-P series for Portland is a good choice. But I don't see a strong FOX in Portland. WPFO is weak and off axis. To make it work you'd need the smallest HD-7694P aimed at 24 degrees and hope that the stronger stations work slightly off the main beam. Plan on a preamp.
Your better option for FOX is Boston's WFXT. A 91XG aimed at 207 with a preamp should work fine for almost all the Boston stations.
Of course a rotor will help with reception of off-axis stations, but some HDTV sets have trouble with rotors. A better solution is combined antennas, but combining has practical limits.
If I lived in York, ME I'd install a 91XG aimed at Boston and a Y5-7-13 aimed at WMTW. I'd use a Winegard AP 2870 to couple the two antennas together. I'd rely on WMTW for local news and weather, the Boston stations for everything else. Would that miss anything important to you?
