Searching your location from your zip code only shows reception from 78, 5, and 240 degrees mqagnetic. So you lost the connection from the antenna, or your set fliped its channel memory. Start by re-scaning your set. Be sure it is set for Air not cable reception. If you have another set with a digital (ATSC) tuner, try that one also. If that fails go to the antenna. Are you using an outdoor antenna? If so check every thing from the antenna connections to the TV. The balun transformer to the TV. If you are using an amplifier, be sure it is pluged in.
