Old 1-May-2012, 3:01 AM   #34
Electron
Tv antennas and Tv reception
For your reception situation you Can Not combine the HD7698P antenna and the UHF antenna together. The two antennas will cross talk and the reception results will not be good. As a test you can connect them together with a splitter connected in reverse , go ahead and try it , the results will not be good.
