I'm not sure which market you're most interested in. You probably cannot get all the Baltimore stations at the same time as the DC stations - they're too spread out from each other. Both markets require the same type of antenna, one that covers high-VHF and UHF bands. The only question is how big?
If you want to go for Baltimore, I would recommend either the Winegard HD7696P or the AntennaCraft HBU-44. Get a rotator and you can swing the antenna over towards the DC stations. If you are really interested only in the DC stations, then the smaller HD7694P or HBU-33 will work.
Good luck.
