Old 1-May-2012, 2:21 AM   #2
signals unlimited
The stations at 338 from DC and 9 degrees from Baltimore should be quite strong at your location. Your reception however will depend on the location, density and height of these trees. If you can work around or over these trees it will make a difference in the equipment we recommend. Your antenna will need to be UHF/ VHF due to 7, and 9 from DC and 11, and 13 from Baltimore. Tell me more about the direction, height, and density of the trees, and how high your roof is, and we can recommend the antenna, amp (if needed), and mount.
