Old 30-Apr-2012, 8:48 PM   #1
joecacti
Baltimore in Building Shadow?
Here is my location / antenna view:
http://www.tvfool.com/?option=com_wr...de650e04b49f75
The transmitter(s) are 5.2 miles away, and by using google earth i can tell that the LOS goes right through a pretty big building about .5 miles away. I have this antenna:
http://www.radioshack.com/product/in...ductId=3740645
I have 1 question: Does the type of coax I'm using matter? The antenna is powered, but it's 50 feet of coax from the power plug up to the antenna. Then the next question: channel 2, 11, and 13 don't work well or at all, but 45, which is broadcast from the same spot, does work. Am I out of luck with this building? Is there a better antenna to use?
Thanks in advance!
joecacti is offline   Reply With Quote
