Old 30-Apr-2012, 4:36 PM   #11
Calpyro
Originally Posted by Electron View Post
Installing a higher gain amplifier , Immediately , puts in my mind , Bad coax connections , bad coax , bad splitters , bad couplers , etc. . Check All connections and coax. A way to prove out reception is to connect a Long Known To Be Good RG-6 coax to the antenna and run the long coax through a open window or door direct to the Tv.
I did run the new RG-6 without anything directly to the TV and still had a problem.
That being said in total, I have around 100' in new RG-6 to the splitter and around 110 of older RG-59 installed inside the walls to the TV's for a total of +/-210'. My original estimations were off quite a bit.
Calpyro is offline   Reply With Quote
