Old 30-Apr-2012, 3:35 PM   #10
Electron
Tv antennas and Tv reception
Installing a higher gain amplifier , Immediately , puts in my mind , Bad coax connections , bad coax , bad splitters , bad couplers , etc. . Check All connections and coax. A way to prove out reception is to connect a Long Known To Be Good RG-6 coax to the antenna and run the long coax through a open window or door direct to the Tv.
