Old 30-Apr-2012, 12:27 PM   #51
samve33
Well, the HBU55 never came back. Atlanta is 0%, Chattanooga is weak. Is is atmospheric or an antenna malfunction? I'm wondering about a malfunction. When I rotate the antenna there is little change in the signal. The tv is on 61 now. I picked it up with the antenna pointing to Atlanta at 35% and rotated the antenna to Chattanooga and the signal was 35% all the way around. Could I be picking up on the coax and not the antenna? When I was putting up the HD7698P I had a couple of the coax connectors to just fall off. Did this happen to the HBU55 after I pur it up?
samve33 is offline   Reply With Quote
