Thread: Antenna for
Old 29-Apr-2012, 12:08 AM   #20
signals unlimited
I only recomended the amplifier to be tried to see if It would improve channel 43. Adjecent channel not withstanding it could work....worth a quick try on the deck. If it should happen to work, I recomended that two coax be run from the antenna. One clean(un-amplified) one amplified. Then the use of an a/b switch would select between the lines as needed. No amplification could or should be used on the nearby stations. No amplifier at all if the test amplification fails to produce, and I admit that it could. Just a test....nothing all that stupid.
