Two things:
1) Rerun your TVFool report for the height you are planning to use. Many of the stations that are listed as "1-edge" will likely be line-of-sight and much stronger. Do not get an amp - it will likely be overloaded.
2) I realize that the HD-1080 is advertised to work with high-VHF channels. However, Winegard's own spec sheet shows that it has negative gain in that band. I second the recommendations in the previous post.
