Old 28-Apr-2012, 3:06 AM   #3
Electron
Tv antennas and Tv reception
The Tv transmissions are Strong at you location.
Here are some Above The Roof antenna mounts , http://www.ronard.com/909911.html , http://www.ronard.com/34424560.html , http://www.ronard.com/ychim.html , http://www.ronard.com .
Buy the ronard antenna mounts by typing the word ronard in the solidsignal search box or buy from ronard.
REPLACE the RG-6 and RG-59 with NEW RG-6 coax.
It looks like a better aim direction is about 140 degree magnetic compass. As Always the aim point is a starting aim point , the antenna can be turned to the left and right to get better reception of the channels to be received.
Pending Applications Included in the tvfool radar report lists the REAL Digital Tv channels that are transmitted and received , and also lists the Virtual channels.
For reception of the green and yellow zone Pending Applications Included , one or two Tv's connected no amplifier is required.
For one Tv connected use no splitter.
For 2 Tv's connected use a 2 way splitter.
For 3 Tv's connected use a 3 way splitter.
For 4 Tvs connected use a 4 way splitter.
For 3 or 4 tv's connected , might require a Channel Master CM3414 distribution amplifier. Try it with a 3 or 4 way splitter first.
Every split that takes place reduces the signal strength.
Here are some places to buy supplies , http://www.solidsignal.com , http://www.amazon.com , http://www.channelmasterstore.com
