Thread: Antenna for
Old 27-Apr-2012, 8:08 PM   #8
signals unlimited
It just dawned on me....Install a good two way splitter/combinder at the antenna. Run the antenna output into the splitter input. hook up any pre-amplifier to one of the splitter outputs, run to the power supply and to an A/B switch. Run a seperate coax from the other splitter output to the A/B and use the A/B to switch from amplified to un amplified. A simple and affordable fix!
