					Originally Posted by  signals unlimited
				No chance that it is an antenna problem. Could be that you have that channel set for SAP.."secondary audio program". look at your audio settings in your audio menu while on that channel.
 I concur. An antenna has no mechanism to decode data and then misdirect it bay altering the 'address' of a particular data stream. An antenna problem would manifest as, 'all TVs have similar trouble receiving a reliable signal'.
This is certainly a misconfiguration of the TV or a defect with the TV. It's far more likely a configuration issue.
