Old 26-Apr-2012, 9:51 PM   #5
Tower Guy
Originally Posted by Rodwalls View Post
Is there a filter or a Pre-amp that will ignore such strong signals?
Preamp, no; filter, yes. CE7W tuned to channels 31 and 32.
http://www.tinlee.com/CATV-ChannelEl...i.php?active=1
Another option is an antenna array that nulls 288 degrees when aimed at the station that you want.
http://www.hdtvprimer.com/ANTENNAS/ganging.html
The plan works off the back as well as the front of the antenna. If you want to view a station at 140 degrees, use two UHF antennas stacked 20" apart. I've done this with a pair of C-2 antennas, but any 2 or 4 bay models would work.
