This is a common problem and sometimes prohibits the use of a needed amplifier. I usually install a rotor in these systems. That allows you to peak these weak channels, and you can move the antenna off a bit on the stronger channels. eliminating the overload. This is a little known advantage of using a rotor that works everytime.
