Old 26-Apr-2012, 5:35 PM   #6
Tv antennas and Tv reception
Tv antenna rotors are Not channels surfing friendly , must wait for the one antenna to rotate. A better way to do it is install 2 antennas and a CHANNEL SURFING FRIENDLY Remote Control A/B antenna switch. With remote control in your hand you can switch from one antenna to the other. Above The Roof at 25 feet to 35 feet install a Winegard HD9095P or Antennas Direct 91XG antenna aimed at 300 degree magnetic. And install a Winegard HD7084P aimed at 195 degree magnetic compass. Antenna amplifiers will not be required for the antennas with one tv connected. Install the antennas with one of these mounts , roof top Tripod mount or Eave Mount or Chimney Mount. Install the HD7084P antenna below the HD9095P or Antennas Direct 91XG antenna on the same mount. http://www.saveandreplay.com , has the antennas and etc.. These are the Tv stations/channels that will be received. CHIF-DT channel 44 Global Maritimes , CBAT-DT channel 31 CBC , CKLT-DT channel 9 CTV , CBAFT-1 channel 5 SRC. Here is an other place in Canada that has antennas and etc. , http://www.trentondistributors.com
